It is currently Sun Jul 27, 2025 11:43 am
PostPosted: Tue Jun 10, 2008 9:39 am
Well, I finally got around to taking my first apart a little over a week ago to finish up the FP process. The back and sides were pretty good, but the top needed a fair amount of work. I had put on a number of bodying sessions over the last week, and last night was glazing. Working away happy as a lark. All of a sudden, I heard the sound of something hard scraping across the top. Yep - fingernail! gaah OK, I did the little oil and 400 grit thing to see if I could sand it out. It wasn't invisible, but I let it go, built the area back up, and went on. In a minute it happened again. I thought I was being careful, but when gliding on and off the top, it's easy to catch the muneca on the edge, apparently. This scratch was long and deep. I ended the night up taking the whole finish off the top, to start over. What a night! I think I'm going to get some of those heavy finger tip protectors for French Polishing. At least that would only leave a rubber mark on the top.
PostPosted: Tue Jun 10, 2008 9:44 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Be glad that's all that happened! You didn't bang it into any machinery or drop it on the floor.
But, yeah, it sucks.
http://redrivercanoe.ca/
PostPosted: Tue Jun 10, 2008 9:45 am
Waddy, good lesson learned! I think I've said before that I always wear a surgical type glove on my right hand when French polishing just for this reason.
PostPosted: Tue Jun 10, 2008 9:57 am
I can assure you I will be wearing some kind of gloves when I do, from now on. I justified it also because I kept seeing things on the top that I did not like. Just little things, but why start with that. It should be as good as I can make it. Hopefully, I am getting better at French Polishing, as I am getting lots of practice. Thanks for your commiserations!
PostPosted: Tue Jun 10, 2008 10:10 am
Yeah wear those gloves that the proctologist wears....... :D
Sorry this happened to ya Waddy bro.
PostPosted: Tue Jun 10, 2008 10:21 am
First name: Jim Howell
Waddy--
I've found out the hard way that you need to remove any jewelry from your hands and wrists and also if you are wearing a shirt with long sleeves and button cuffs, roll them up! The spruce is pretty tender and darned easy to dent. You might be able to steam a lot of it out.
Jim Howell
Charlotte, NC
PostPosted: Tue Jun 10, 2008 10:30 am
When I got down to wood, the scratches were light, and in the upper bout primarily, so I sanded them out. They did go all the way through the finish though. As I said though it allowed me to sand out a couple of other imperfections I had seen after getting finish on the top. Little things don't show as much on back and sides, but sure shine out on the top, don't they?
Users browsing this forum: ChuckB, Facebook [Bot], George L, Ken Lewis and 18 guests
